I’m running into an issue where the pedalboard (I’ve created two version of it) keeps freezing up after some time and the screen of the mod duo x locks (all four buttons at the bottom are highlighted even if I only assign things to 1 or two of them).
I’m using a mod duo x and the pedal locks up after multiple presses of the second button which trigger the multi button to CV pedal press. The single press CV out goes to one of the freeze pedals and the other freeze pedal gets the output of the CV Logic pedal (so one pedal gets “0” while the other is “10” and vice versa when you press the pedal button). The Pan of channel 1 and two of the lower mixer (coming from the two freeze pedals) is triggered to be almost opposte with an LFO CV out for channel 1 and the Attenuverter of the LFO for channel two.
Pedalboard is here DoubleFreeze - MOD Audio for a messy on with no outputs attached and Multi_Freeze - MOD Audio is a clean version.
@DaveM it may be related to the memory on the Freeze pedal (I think you’ve made some of the best pedals here so calling this out as a tester, not complaining about the great work).
The end goal was to create a board that when you flip from one pedal to the other it sustains a new piece of music and has some overlap.
Thanks,
Aaron
