Hi, I’m asking for support from someone on the MOD Team.
I had always used MOD DUO X with synth and Stab. Today, almost for the first time, I tried to pass a normal Analogue BassDrum through a TippTop Audio 808 module and I noticed how much the passage through MOD DUO thus degrading the signal. Same thing with a sine wave as well as a modular one, the result it’s even worse.
There is no pedalboard loaded, just direct switching and Gain set by default. In the soundcloud example I put a marker/comment that divides the bypassed signal. The difference with the original, round sound of the bass drum is truly enormous. What’s wrong?
I use analog outputs so no S/PDIF and A/D conversion.
