Description
If there is already an existing Ableton Link Session running (for tempo sync) and I (re)connect the USB or reboot the MOD, the MOD will set its last known tempo to the existing session.
How to reproduce
- Start a Software which supports Ableton Link (here Ableton Live Lite) and enable the LINK (e.g. with Tempo 55 bpm)
- Conncet the MOD via USB to the PC
- Set the Mod Duo to ‘Sync Mode’ Ableton Link --> MOD will sync onto the Link session and take up the current tempo (55 bpm)
- Now we could assume we loose connection via USB, or need to repower the Mod, or connect ourselfs into a bigger set of already running Ableton Link session --> so disconnect the USB or power off the MOD
- Now change the Tempo within the software (from 1.) as the song or the current tempo might have changed (e.g by someone else participating in the Ableton Link) -> the tempo is now at e.g 78 bpm
- Results:
- 6.1. after Reconnect the USB
6.1.1. when the Ableton Link Session itself was not restarted during disconnection --> MOD syncs to current tempo (here 78)
6.1.2. when the Ableton Link Session itself was restarted during disconnection --> MOD sets the tempo to its last known value (here 55). I think this is not ok, but I don’t know the specs. - 6.2. after Power on the MOD
6.2.1.without USB connected during boot --> ok, it syncs to the session
6.2.2. with USB connected during boot --> not ok, it will just set the tempo to some? previous tempo value - here I had the impression that the behaviour is additionally depending if the MOD’s transport was running or not before power off.
Expected/suggested solution
We see that the behaviour is different, depending on what happenes to the MOD and/or the LINK session.
I would suggest that the MOD’s Ableton Link becomes something like a “passive” option during boot or reconnect.
I suppose that if Ableton Link is used as Sync input, there is very probably a session already running when the MOD is (re)booted or reconnected due to whatever reason.
Assuming when something similar would happen during a live gig with a bigger setup and more musicians the current behaviour could mix up everything tempo related.
Additional information
This was tested/documented with modduo-v1.10.0.2141 and Ableton Live Lite 10
