MOD Duo - no connection
This is a companion discussion topic for the original entry at http://blog.moddevices.com/blog/2017/03/10/1-3-Update.html
The 1.3 updated is so old … does this even matter?
Mi Mod Duo no se conecta en ningun momento…
Ya he actualizado a la ultima version en dos ocasiones y sigue sin conectar
Ola,
¿Podrías usar el inglés para comunicarte con el equipo de Mod Audio? Esto permitiría una mejor gestión de su problema?
@Blasfemino have you reached out support@mod.audio?
Please do it and give us your device serial number there as well.
Side note: as @Azza mentioned, our support is mostly provided in English, so if you can write in English (even using a translator) it will make it way easier for us to help you.
Ya he podido solucionar el problema, al reinstalar el firmware se ha desbloqueado. Gracias por su interés
I’m glad you managed to solve the issue @Blasfemino. Feel free to reach out here or in support anytime you need help (although if you use English it will make it easier for all os us to help you).
