Mod Duo freezes with Midi controler
Hello,
I bought a Roland FC 200 MIDI Controller.
It seems to work.
However, when I connect it to my Mod Duo Kickstarter Edition, I manage to switch pedalboards once or twice, and then the Mod Duo freezes.
Do you have a solution, please?
How fast are you sweeping between the pedalboards?
If you click to the next and then immediately to the next and so on, you may crash the device because every time you select a new pedalboard, all the plugins are loaded, and if you are “too fast,” you overload the device and it crashes.
This can happen on any device, but the MOD Duo, as it’s older, has a weaker CPU and therefore requires a little bit more time to load the pedalboards.
Hi and thanks.
When I switch fast, I can understand, but here, maybe around 15 seconds between swtichings is required…
Update problem perhaps, no?
It’s hard to say exactly how much time is needed. It really depends on the plugin. Heavier plugins need longer, lighter ones need less time. But that’s all somehow relative.
