i had the hardware fix done… that improved things a fair amount. subsequent software updates improved it more, and there’s now a mainline kernel version available which ~also~ addresses some lingering xrun issues.
i ~believe~ you need both the hardware fix and the software updates to have maximum noise reduction on the Duo; i guess you could install the latest, mainline kernel software version to see whether that alone is an adequate fix for your use-case.
…also, perhaps MOD folks (who might be able to actually quantify the improvement offered by each approach) will chime in with more definitive answers…
Thanks for your input.
I have the latest stable software release (v1.9.0) intalled.
About the mainline kernel I think you are talking about this topic?
[Continuous Xruns]
Let´s wait for the MOD Team on this subjects.
In the mean time having the info about the hardware fix will be nice.
Can you help me with this @dwek?
Just purchased the Mod Duo. I love the interface and the endless possibilities, but like everyone else here also am experiencing background noise. It was really bad at first, but I used a different USB plug and that solved the really loud part of it, but the noise level is still significant enough that I couldn’t record quiet passages with this thing. Very unfortunate. I considered returning the unit but it does offer such great avenues for experimentation that I will keep it. Two questions:
Reminder that connecting any audio related stuff to a PC via USB can introduce a ground loop and make some noise, and this isn’t related to the Mod Duo noise problem.
I don’t believe the USB is my issue. I did have that problem, I used the USB isolator and it went away as has been suggested. What remains is still a noisy signal. I can live with it to play around with, but I can not live with it for recording - very unsatisfying.
The “noise thing” happens specially in my Mod Duo X, but also on the Mod Duo. I have just two plugs for everything in the studio, and several “plug strips” (I don’t know if it’s well said in english, a thing to put several sockets together, in spanish we call it “regleta”). Sometimes it’s difficult to have isolated the Mod Duo, as plugs aren’t infinite.
Does anybody recommend any USB isolator tested with any of the DUOs?
Indeed your only two wall plugs are a big problem.
Do you have more noise if you connect to the computer? Is that why you are asking for a USB isolator recommendation?
my experience was that the PWM from the display backlight was causing the noise. setting the display to 100% brightness fixed it! as an aside, I had trouble tracking this issue down because my modular was also creating noise… from display screen backlight PWM on a few of the modules! now my setup is noise free… and a bit bright!
Hi guys!
I have the noise issue with my guitar on input 1 of my Mod Duo.
The input 2 is ok.
I plugged my guitar in a active direct box and the box in input 2. The problem is gone.
I hope it will work for you.
Hi - I am picking up at the start of this thread.
I wanted to start a new topic about how to best integrate the Duo X into a live pedalboard to ensure best performance (ie. start of chain, does it need to have a lot of gain built in etc).
I recently added to my live pedalboard (which has ~ 12 pedals) and the Mod seemed to get overwhelmed and its output suffered.
Any thoughts or insights on this topic would be very valuable.
Hi Palty, this seems like a great idea for a thread!
My first thought on your question may be kind of obvious, but here it goes…
If you are using an overdrive, distortion, compressor, or gain pedal it’s probably wise to be really picky with its placement in order to prevent for example electric hums amplification or other not wished noises (this is actually a general thing, not just for the DuoX).
I would maybe start by trying the DuoX by the end of your chain and use their inputs to control any unwished noise from all the setup.
Just a suggestion, go ahead and share with us the results of your experiments (maybe in a new thread, indeed).
is there any major improvements on this issue?
i still have some low frequency noises when Mod Duo is processing some effects, not bypassing the signal.
i’m kina sensitive to noise issues and set my equipment without any ground loops, electro magnetic inteferences…
