This is less a bug in terms of something being totally broken than not functioning as I’d expect. The pedal sounds great, actually better than the real thing which has a bit of a “farty” bottom end. The issue is the sweep of the Dist is off. It seems to be nearly ineffective until it’s up to 3 O’Clock mark and then rapidly increases. Looking at the parameter values .01-.47 happens over that large sweep where there’s not much change in gain, and then it zooms from .47 to .99 in that last quarter turn. The sweep needs to be adjusted in order to easier dial in the correct amount of gain.
