Description
The CV port label on the CV Logic plugin has white text, so you can’t see it.
How to reproduce
Add the plugin and turn on CV port management
Try to name the port
See that the name does not show up
Expected/suggested solution
Text should be black.
Additional information
release: Mod Dwarf 1.11.2.2677
Operating system: Winows 10
Browser: Chrome 98.0.4758.82
jon
February 21, 2022, 11:16am
#2
Have you added any name on the port?
If not, I would say that is normal that it doesn’t consider it created.
That port in the screenshot was named, yes. Also, the default names also don’t show up.
And the problem wasn’t that it wasn’t showing as created — all the logic worked fine, it’s just a CSS problem.
jon
February 21, 2022, 2:07pm
#5
ah so you named it, but the name was not appearing. Is that correct?
Yes. The text is there, it’s just in white on a white background — you can see it if you select it.
I’ve encountered the problem once or twice with all the CV labels, though I don’t remember if it was reloading the web page or reseting the Duo that fixed it.
In this case, it was just this single plugin — all the rest of them were fine, but every instance of this plugin had the problem.
jon
February 22, 2022, 10:19am
#9
@Dymaxion I believe this may be related to some browser cache.
Are you able to try an incognito session or a different browser and confirm if the issue is still there?
Looks identical on Firefox current.
jon
February 24, 2022, 2:18pm
#11
You are right. I quickly tried the plugin and an incognito session and the same happened to me. I will report it.
