MOD - Convolution Reverb
I haven’t heard about that. Is there a reason ?
I don’t know. That was just a suggestion because the developers don’t consider the plugin stable.
No, I only have a Dwarf. I may try but I must confess I’m not even planning to use the Convolution Reverb in my pedalboards. There are so many plugins in the store that it’s hard to make a choice so I eliminate the ones that use too much CPU, especially when there are good alternatives. There are good algorithmic reverbs, like CAPS Plate, which are not ressource hungry.
@funkypou has a point here. @Julien Can you make a copy of the pedalboard with no beta plugins and confirm if the same behavior still happens?
Ok. I’ll try that today and confirm.
