Mod / Beebo comparison; My opinion
I had the wonderful opportunity to check out Poly Effects’ Beebo, a pedal with a similar yet very different concept to the Dwarf. I would like to offer you a brief comparison of the two pedals and my opinion. This is my personal meaning, I am not an official tester of Gear or something conparable :grinning:
First, the hardware: Both devices are road-ready, would I say. I must say, however, that the Dwarf seems much more robust. The Beebo also has a metal chassis, but it doesn’t have the monolithic character of the Dwarf. Perhaps this is because the Beebo consists of two housing parts that are screwed together. The rotary knobs and foot switches feel slightly wobbly on the Beebo and the sound is hollow, which doesn’t exactly suggest solidity either. But it’s okay. I had to pull the rotary knobs out a little bit first because they were dragging on the case with a nasty noise… hum.
I of course ordered the pink Beebo… if you’re going for it, then go for it… that looks cool, of course, if you like it… :smile: The Dwarf, on the other hand, is kept in a serious but also somewhat boring black.
To cut a long story short: I like the Dwarf’s hardware a lot more, it seems much more robust.
The concept of the two devices appears similar at first glance, but they could not be further apart. The effects of Beebo are selected from a list, similar to the Dwarf, and then wired together in the main screen. But that’s about it for the similarity. The concept reminds me more of a Headrush or other deveices that have a touchscreen. Then this is the biggest difference to the Dwarf: You work with the Beebo exclusively in the screen of the pedal itself, but with the Dwarf in the browser on the PC.
This has advantages and disadvantages, of course: With the Dwarf, I need a PC to build my pedal boards, but not with the Beebo. However, I sit comfortably on my chair and work on a large, clear screen when I operate the Dwarf, but with the Beebo I fumble on a small screen with back-pain and try with my clumsy fingers to always hit the right button. Don’t get me wrong: Both have something. However, I much prefer working on the large screen.
But now to the most important topic: the sound and the plug-ins:
If you look into the Beebo plug-ins as a Dwarf user, you will meet some familiar plugins again: Many reverbs for example but also other plugins that I use in Dwarf (e.g. the whole Convolution set) I also find in Beebo. But that makes a huge difference for me: In the Dwarf I can tweak the sounds, in the Beebo this is often not possible. There, the tweakability is replaced by a variety of different reverbs. Maybe I did something wrong here, but if so, the usability needs to be improved again. I haven’t figured out how to change the parameters in a way comparable to the Dwarf. This was the biggest weakness of the Beebo for me. A second serious drawback was the latancy: with some plugins, this was so large that you could hear it loosely. Maybe it was not a bug but a feature, but then this was not written anywhere.
Where the Beebo has clear strengths: Gain staging. This is not a comparable problem, as for the Dwarf, at least I have not perceived anything like that.. So it doesn’t happen what sometimes happens with the Dwarf; You take a plugin into the pedalboard and all of a sudden everything is only half as loud or it’s way too loud and noises miserably. Here, the Dwarf has a clear weakness, which must be better communicated or worked on.
But now comes something surprising: The Beebo also has a problem with background noise. In the meantime, I know my way around the Dwarf so well that I have managed to suppress the noise completely, meanwhile even with the original power supply. I did not succeed with the Beebo. It may be that I needed more experience, but for a system with proper gain-staging, as it is the Beebo, I would have liked less noise.
The sound of the plugins is excellent on both devices (if you use the Dwarf correctly). However, I must also say that I sometimes watch comparisons on YouTube and am always amazed at how different some sounds are supposed to be according to the tester and I hardly hear any difference. Maybe they should make more music instead of paying attention to per mille in the sound design…
You notice with the Beebo that the manufacturing company has a lot to do with synthesizers, because many effects / plugins / methods come rather from this corner. The selection is somewhat different than in the Dwarf, there is also a lot of crazy stuff, but I personally rather not use.
My personal conclusion: When I operated the Dwarf for the first time, I was immediately thrilled. The first pedalboards still had decent background noise, but it was clear to me that the device will fully meet my needs when I get a little familiar with it. I didn’t feel that way about the Beebo. I was rather annoyed after a while: this fiddling with the small screen, the latency of some plugins, the background noise… already the fact that I had to pull the knobs out a bit so they wouldn’t drag on the case… Somehow the Beebo is not my device. I had the idea that you could do cool things with Dwarf and Beebo in combination. I have to say, better two Dwarfs then.
Thnx for your comparison!
What do you mean by this? The Beebo mostly uses the same technology as MOD. They use a different plugin host called Ingen, but many of the same LV2 plugins. Most of the code is up here: Poly Effects · GitHub
Yes, you’re right. But the gain-settings are synchronized and consistent. You don’t have the issue that one plugin in the pedalboard changes massively the gain or volume. At least I have not perceived anything like that. May be Poly effects have a QA on that. I expressed that badly, sorry.
It could be that they have accounted for it in their builds of the plugins. Which unfortunately would cause breaking changes to existing pedalboards so not something we should probably apply retroactively.
This might be the case. I have rephrased the sentence again
Thanks one more time @Kim for such a thorough comparison. I wish I could say I had the same experience, but my time with the Beebo was very limited.
You’re very right in one aspect: you don’t destroy your eardrum by dropping an effect in your chain with the Beebo.
But certainly to be thought of and applied moving forward. It is one of the chief complaints of the Mod platform and perhaps the chief reason it never had its real breakthrough in North America.
I have two Beebo’s and use them as effects devices for keys & strings. But one of the things that I discovered is that since they have 4 input/4 output routes, I can take the two devices and jack multiple physical fx pedals into real-world sub-chains and use MIDI to control the IO, making the Beebo’s a convenient parallel blender. This may sound like an underwhelming application considering that it doesn’t flex the processing power they contain, but having some EQ, LFO & gain control on the actual signal pathways makes the smoothest switching system I’ve ever worked with.
I have a Beebo as well, and honestly had the insolvency not been worked out I was going to go back to it full time. I prefer not needing a computer to edit (something the Dwarf was supposed to have as an option but has not materialized), and everyone who complains about the skeuomorphic nature of the Mod system should love the Beebo’s interface (me, I don’t mind the graphical pedals in Mod).
Moreover, Loki is pretty responsive to user suggestions and relatively quick to update; and he programs, designs the UX, and designs & manufactures the hardware all himself. I think he has one employee besides himself, and she’s a recent add.
You can use multiple instances of his convolution reverbs with no glitch. Same goes for your own IRs. His looper gives Looperlative a serious run for its money; it’s based off the Echoplex Digital Pro.
Where the Dwarf beats him is the number of knobs and the pagination buttons. Even though the Dwarf doesn’t let you program the leftmost foot switch, overall it’s much more flexible on the floor. With the Dwarf, I could probably (and am working towards) making it through a gig with just the Dwarf alone; with the Beebo I don’t think I could manage without my Morningstar MC6 (and I’d honestly want a Faderfox EC4 with me too). He told me a month or so ago he has a plan to make the knobs experience better, but he’s been busy launching another pedal.
He also has fewer guitar- and bass-ready effects; they’re there but his focus is on the modular synthesis aspect… you can build your own effects out of his plugins (which are all, as has been noted above, open-source and frequently the same—his freeze effect is the Infamous Stuck, for example, although his implementation isn’t as clean) but you gotta be really into modular synthesis to dig that deep.
Anyway… I’ve always felt like there’s some magic middle ground somewhere between the Dwarf and the Beebo—someday I might rebuild the Dwarf housing and use a Raspberry Pi to install an iPad-mini-sized touchscreen that’s permanently wired into the web appliance for a pedal with the Dwarf’s buttons and the touchscreen all right there. Who knows?
There is, and one such product is not too far off the radar. I estimate a 350-400K investment to put a together a system with multiple I/O, different modes for performance and programming, a slightly larger screen, computer editor, and the ability to host different plugin formats.
There are other OS versions and hosts for that, being that a VST host with Elk OS and a board using an Atom x5-Z8350 processor has already been developed and it worked. (It was not meant for mass production, but it’s just a matter of someone wanting to invest in that.)
MOD could step ahead of that with 2 things: one is revamping the UI – like creating a “macro” developing screen mode that resembles the Helix and even the Beebo – and making functions like copy and paste available, and the other is harmonising (or normalising if you will) the inputs and outputs of all existing plugins. Now, I know it’s easier said then done, but these above are already much discussed and long overdue improvements.
On the other hand (picking this thread back up as I’ve just been playing through my Beebo for a couple hours), the fact that it lacks fewer assignable knobs is less of a problem in practice because you can just press a plug-in on the screen and access ALL the settings right there. You gotta kneel down for an assigned knob as low as you do a touch-screen slider.
The Dwarf still beats it on foot switches, though. The Beebo has more assignable physical buttons but a maximum of five options per patch, whereas the Dwarf has 2 (assignable) switches x 8 pages x the Multi-Button to CV’s 3 options for a total of 48 potential foot switch actions per pedalboard!
I realize that the MOD team has enough on their plate, but I wonder what it would take for each plug-in to be adjustable in a similar manner to how it’s done on the Zoom MultiStomp pedals, which also have three knobs, three buttons and a lo-rez screen—but which are set up to where you can page through each parameter. That way we can assign our favorites/most needed parameters to the knobs as appear on the device pages, but could go deeper if needed.
