Hi @x42,
I am using your MIDI Transpose and I noticed that on the plugin it says “MIDI CC to Note”…
I’m guessing that you copied/pasted some code and missed that piece of text…
Also, the on/off button is hard to use in the GUI. I can do it with my pinter right at a small part of the base of the button…
Anyway… It works perfectly otherwise…
I’m using on this pedalboard. https://pedalboards.moddevices.com/pedalboards/57e8837afca7d905dacbbe55
x42
#2
The title was indeed a copy/paste issue. Already fixed:
Thanks for the heads up about the bypass button: also fixed just now:
falkTX
#3
Fix should be up now, just update the plugins.
