MIDI Note/Channel Map - MOD Devices
Robin Gareus
12-tone channel map. Allow to change midi-channel per note. (Events other than note-on/off will be passed through as-is; currently there is no channel panic forwarding, nor note-off events when changing the channel-assignments dynamically)
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL2dhcmV1cy5vcmcvb3NzL2x2Mi9taWRpZmlsdGVyI21hcGtleWNoYW5uZWw=
