I would like the ability to press a button on my midi keyboard to trigger the tuner. I think a settings panel in the mod ui would be the easiest way. Maybe it’s nice for all the other global settings too.
I have to ask, what exactly is the purpose/intention here?
There’s a dedicated button for it as close as possible to the screen…
At a gig I have to tune several times. It’s more convinient to press a button while standing than to bend down. Before I used a korg pitchblack where I had a footswitch. I think for people with additional footswitches it’s nice too. Especially because it’s an easy way to mute the guitar. I would keep using the pitchblack at concerts because of this.
What if you create a plugin like the true bypass plugin? Would that be possible?
I’ve done a couple gigs and many band practices with my MOD. I use my foot to push the upper right knob (the one close to the screen) down while I am standing. I use the bar that runs across the top of the pedal as an “anchor” and then tip my foot forward till I “click” it and go into tuner mode. I’m not the best at balancing, but this goes well.
Let me know if that helps.
Yeah this technique has worked well for me. The only downside is that sometimes I’ll end up twisting the knob a little bit when I try to engage the tuner.
This is currently not possible right now, but we’ve added it to our backlog of features to implement.
