I’ve been trying to assign a MIDI CC pedal to vary the mix control in the FOMP delay. I want to go from 0 to 0.35. Assigning the pedal via MIDI learn is easy enough, but when I click the advanced options button, and set the range and sensitivity, it won’t save that data… The range always goes back to 0-1
How to reproduce
select MIDI learn from the actuator drop down,
move pedal
open Advanced drop down
set range to 0 - 0.35
set sensitivity to high
click save
move pedal - everything resets.
Expected/suggested solution
would love to have the range actually set the min/max for what the CC pedal (set to 0-127) will actually effect…
Additional information
release: 1.0.5
controller: 7497014
Operating system: Windows
System version: Windows 10
midi controller - KMI softstep, with connected Exp pedal, connected to the Modduo MIDI port via the MIDI expander.
Would be properly brilliant if that range thing gets implemented. That and multiple functions assigned to a single Midi CC/program change are top of my wishlist, by miles
BTW, that’s me having set the values to where I’d want them to be, before clicking save - they go back to 0-1 range and mid level sensitivity straight away…
the Keith McMillen stuff has an interesting way of implementing sensitivity - especially when you’ve changed the range so it’s not 1:1 with the 127 steps of the cc command - it’s about dealing with the signal coming off an analog cc pedal, so I guess it all has to happen at the Softstep end, cos it’s already converted by the time it gets to the Mod
…and I do use that pedal for pitch bend a LOT (so sensitivity is a HUGE issue, however it gets implemented) - is there an octave up effect available for the MOD yet? If not, I’ll have to do a deep-dive into how to port MAX patches over here, and get one of my MAX ninjas to write me one
There is a pitchshifter plugin that can pitch up (or down) 1 octave or more.
But as of right now it still consumes too much cpu to be really usable.
As soon as we’re able to optimize it nicely for ARM, we’ll push it to the store.
thank you! Very much looking forward to trying it out. It’s one of the very few things my Lexicon MPX-G2 has that I use a lot that I can’t yet do in the Duo…
Let me know if you need testers as you progress with it!
in 1.3.0.302-RC1, the Range advanced settings don’t seem to save… i’ve tried various plugins, but the range always goes back to the default after saving. (this is on MIDI-learned CC ranges on plugins without a MIDI input)
is range on CCs only implemented for plugins with MIDI input, NOT on MIDI-learn?
I am still using 1.2 (don’t know which exactly - the last stable version) and the range settings are just saved the first time I am using Midi Learn.
So if I select Midi Learn, set the range values, then save and move the fader it works. Changing them later doesn’t work (I’ve used my expression pedal with the Gain Plugin). If I wanted to change them I had to select Midi Lean once again.
This doesn’t mean that the bug doesn’t exist - it is meant as a workaround.
