MIDI Keysplit - MOD Devices
Robin Gareus
Change midi-channel number depending on note. The plugin keeps track of transposed midi-notes in case and sends note-off events accordingly if the range is changed even if a note is active. However the split-point and channel-assignments for each manual should only be changed when no notes are currently played.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL2dhcmV1cy5vcmcvb3NzL2x2Mi9taWRpZmlsdGVyI2tleXNwbGl0
