Hi, to plan the setup of my board when the first Dwarf betas are shipped I have a question regarding midi and snapshots (if anyone can answer that already, since I don’t know if that’s a feature that won’t come until the Dwarf.).
I want to do the following: Every song of mine gets a pedalboard. For each song part that has a sound on my other multi FX (Boss GT1000core) I want to create a snapshot. Then when switching the snapshots the Dwarf should set the corresponding sound via midi program change on the Boss.
I had asked the question I think at the start of the Kickstarterkampage at Kickstarter with the hint that this should be possible with the plug-in “the infamous mindi”. Now I have the following questions.
- Has anyone worked with the plug-in before?
- If so, how does it work?
- Is what I described above so feasible?
Depending on the answer, I would have to see if I have to put my old, self-built solution back into my board or maybe rely on an external controller like the Pirate Midi Bridge 6 currently running on Kickstarter, which I was told should be able to do this.
