Hi! Enjoying the amazing possibilities of Mod Audio!
I wonder if there is any way/plugin to filter out midi clock from an external source?
I am well aware of Midi sync options, but in this setup both Squarp pyramid, Linnstrument (and I think Continuumini) is sending midi clock to ModDuoX, causing it to more than double and fluxuate in tempo. Its making quite an interesting effect where synths are tight, but delays vary in tempo.However I would also love to have a tight sync for my FX. I tried Midi event filter, but it doesn’t filter Midi clock AFAIK… Any ideas?
Setting it to internal sync and then set tempo manually works, but I would love to sync with Squarp pyramids Midi clock only.
This is not something you can fix with a plugin, since basically the entire MOD-Host is being synced to multiple clocks.
In this case we would need a way to select the specific device/port that the clock of the Host should be synced to.
Thanks for the quick reply! I see. I was hoping it wasn`t so. Would be great to have this feature in the Mod firmware, but I guess this is quite a niche thing and far down on the list? So then the best way is to have clock filtering prior to the ModDuoX. Through a hub or within the midi controllers themselves somehow disabling “midi thru”?
Maybe host sync through CV could be possible? Assigning internal tap tempo to a CV button, triggered through CV in?
Hey @Imaginus,
I’m not familiar with any of the devices that you mentioned (except the MOD Duo X, of course), but are you somehow able to turn off the MIDI Clock send on them?
I did a quick research and apparently, on the Squarp Pyramid you can do it on a port basis (I found that info here). Altough that is exactly the one you want to use as a master.
On the Linnstrument, that seems to be also possible on the MIDI column of the Global Settings menu.
On the Continuumini that seems possible using something called the “EaganMatrix Editor”
