Robin Gareus
Chromatic transpose of midi notes and key-pressure. If an inversion point is set, the scale is mirrored around this point before transposing. Notes that end up outside the valid range 0..127 are discarded.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL2dhcmV1cy5vcmcvb3NzL2x2Mi9taWRpZmlsdGVyI21pZGl0cmFuc3Bvc2U=
