The Dragonfly Reverb series are available for MOD.
Finally a plate… so good…
EDIT: or am I thinking of a spring… it’s late and I’m drunk foruming…
The newly pushed, also in beta with no guis, airwindows pocketverb has a spring mode.
I’m seeing severe CPU spiking on the Room plugin. The other ones are fine but the Room is not usable on my Dwarf.
I’m running the 1.12 series firmware. I’ve been meaning to do testing on this with older firmware releases, but haven’t had time and wanted this to get on the radar.
@FistfulOfStars I have the same with the room effect. It is somehow pulsating and clicking.
@Kim and are you running an older version?
We will check that
@jon No, I tried to make an upgrade: it is the latest version. It sounds like a loop that is not done well. it is clicking about three times a second.
Plugins have been updated, though still in beta.
Quite a few optimizations are now in place, making the room reverb usable.
It takes a LOT of cpu, but does not trigger xruns anymore.
Testing / feedback for them is appreciated.
Also, initial work started for the GUI, but not yet finalized.
Thanks @FistfulOfStars for the design work!
Plugins have been updated, now with modguis implemented for all 4.
They are not finalized yet, in particular the list-type parameters are not implemented yet.
I think these look absolutely fantastic! Distinct, clean, clear, and a very nice homage to the original desktop plugins!
Good luck with finalizing them, but I will already start playing with these for my various reverberation needs
Another update. Presets (based on desktop version) have been added to Hall, Plate and Room reverbs.
Alike desktop, they won’t change the dry, early and wet levels. Which is a bit unusual for the platform, so we will add a note about this on the plugin description later on.
And another update, getting close to finalize the work for bringing the plugin to MOD.
The enum/list type parameters have been implemented.
Early Reflections now has a default preset.
The new x42 IR Convolver with a good Spring IR does wonders
Hello @gianfranco Gianfranco,
any hint for finding a good free spring IR for my NAND Duo?
Greetings and God bless
Dragonfly reverb plugins have been moved to stable.
The 4 of them can be seen in Plugins - MOD Devices
