If you are using anything other than 1.10.4, this can be a false positive.
Update to it and retry.
If you are unable to access to web gui, follow the steps in Releases - MOD Wiki to manually update.
I click ok on the right button and I have no reaction when I find click or turn the left button
for information I had a problem during the last update
No respons ?
So what version do you have installed now?
I had the problem during the update entry 10.3 and 10.4.
thanks
I am pretty sure this is fixed in v1.10.4, as others that had the issue confirmed it.
Please reinstall v1.10.4 again, to make sure you have that version, instructions at Releases - MOD Wiki
Thanks, but the problem i don’t have reaction when i turn the left button.
other solution ?
Just press down on the left encoder and button while powering on the unit.
It will boot into restore/upgrade mode and you will be able to apply the 1.10.4 update.
thanks a lot
