The Mesa™ Boogie 4×12 Rectifier cabinet is probably the most wanted guitar cabinet of all time. Metallica, Foo Fighters, Soundgarden, Wes Borland - the list of successful bands and guitarists using this cabinet is beyond comparison. Its tight attack paired with a powerful top end sound has shaped modern guitar sounds for the last 30 years. Four UK Made Celestion™ Vintage 30 speakers are loaded in this Mesa™ Boogie 4×12 Rectifier cab, which are carefully captured to spark in your mix! Each IR is available in three variations: Tube provides a warm low end response and subtle tube distortion, Solid (State) gives an uncolored representation of the cabinet and S.P.A.R.C. is a unique flavour with a balanced frequency response that helps you cut through the mix. To create the impulses, the following microphones were used: ShureTM SM57, SennheiserTM MD421-HL (Vintage), AudixTM D2, AudiotechnicaTM AT4050, SennheiserTM e609, AKGTM C414 B-ULS (Austrian made), ShureTM SM7B, t-boneTM SCT800, BehringerTM ECM8000 Features: Impulse responses by forward audio Plugin by MOD Devices (*) "Other product names modeled in this software are trademarks of their respective companies that do not endorse and are not associated or affiliated with MOD. Celestion, Marshall, Shure, Sennheiser, Audix, Audiotechnica, t-bone and Behringer are a trademark or trade name of another manufacturer and were used merely to identify the products used in the creation of this product. All other trademarks are the property of their respective holders."
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL21vZGRldmljZXMuY29tL3BsdWdpbnMvZm9yd2FyZC1hdWRpby9tZWdhLWNhbGlmb3JuaWEtcmVjdGlmaWVy?fbclid=IwAR1OJNad4TBAnSQkUPrDONWhxf5o8Fzpx6-D0V_d9CR79B5wU2aflK63x2E
