MDA Tracker - MOD Devices a drum beat through this and it really seemed like it didn’t work. Not sure if there is a better place than this?
This plugin is still in beta, that means that lacks testing and it can be a bit (or really a lot) “buggy”. Possible even to not work at all as it seems to be your case.
Can you tell us what is your firmware version and if it doesn’t work in all pedalboards or just with some particular effects in the mix?
