MDA SubSynth - MOD Devices
MOD Team
More bass than you could ever need! Be aware that you may be adding low frequency content outside the range of your monitor speakers. To avoid clipping, follow with a limiter plug-in (this can also give some giant hip-hop drum sounds!).
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL21vZGRldmljZXMuY29tL3BsdWdpbnMvbWRhL1N1YlN5bnRo
