MDA RePsycho! - MOD Devices
MOD Team
Event-based pitch shifter Chops audio into individual beats and shifts each beat downwards in pitch. Only allowing downwards shifts helps keep timing very tight - depending on complexity, whole rhythm sections can be shifted! Alternative uses include a triggered flanger or sub-octave doubler (both with mix set to 50% or less) and a swing quantizer (with a high threshold so not all beats trigger).
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL21vZGRldmljZXMuY29tL3BsdWdpbnMvbWRhL1JlUHN5Y2hv
