MDA BeatBox - MOD Devices
MOD Team
Contains three samples (kick, snare and hat) designed to be triggered by incoming audio in three frequency ranges. The default samples are based on the Roland CR-78. To record your own sounds, use the Record control to monitor the plug's input, then with the source stopped select the slot to record into, play your sound, then with the source stopped again, switch back to monitoring. This process is easier in an 'off line' editor such as WaveLab, rather than during a live mixdown in a DAW.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL21vZGRldmljZXMuY29tL3BsdWdpbnMvbWRhL0JlYXRCb3g=
