Max Msp 5
Hello! i have max msp 5 installed on an old computer. Someone already used or know if it can work with modo duo x? or does it only work with newer versions of max msp?
thank you in advance
The MOD package requires [gen~] and Gen Code Export. Only the contents of a [gen~] object are what makes a (very basic) LV2 plugin. Nothing outside of the [gen~] is ported.
I don’t believe code export was a feature available until Max 6.3 or something.
Ok. thank you for your answer
For what I know gen was implemented somewhere on the version 6 of MaxMSP, so as it is a requirement for developing for MOD, I’m afraid that it may not work :confused:
