Hello,
Q here about plugin created with Max Gen~ objects:
Controllable parameters are assignable with the ”param" object,ex: param speed @default 1 @min 0.5 @max 2 which can be then assigned to a knob on the Mod Device.
I need to assign switches to triggers and not knobs ( I know this can be done in the PB via a CV plugin, but it’s not very elegant building a plugin to share not immediately functional…)
How is it possible, any gen~ object?
Should I compile the plugin and then edit the .ttl file , and how… ?
Same question ( @SHIRO-Plugins ? by the way, thanks for your wonderful plugins ! ) for “select options” like seen on the Shiroverb MKII : Interval, Roomsize, Trails are assignable to (and scrollable from) footswitches, bravo…
And last question: why is my plugin labeled “TRIAL” in the Dwarf, muting audio at regular intervals ?
How can I remove this Trial mode ?
Best
