I came across the Mod Duo. I was looking for something that is very generic, has quality sound and is programmable to some extend. I would like to understand a couple of things about it.
I am used to using presets. For example switching from a chorus/delay sound, to something entirely different like a distorted sound with octaver should be possible by pressing a foot switch. Is this possible? Can I browse through presets using the foot switches? Or would I need an external foot switch (is that possible)?
Do I understand correctly that one plugs in this device directly between an instrument (guitar) and a power amp section? There is no need for a pre-amp (because of all the simulators)?
Can I use it in combination with my two favorite, analogue pre-amps? I guess I would need something like a MIDI controlled A/B switch for amp switching, and a MIDI controlled relay switch for channel switching. Or a loop station all together. Can I program such devices in a preset?
Would it be possible to start and stop a audio sample using the Mod Duo, ideally having that sound send to output2, while having the guitar sound being send to output2 ? Or even better, having that sample sound being send to the headphone output, so I can mis-use that as a separated, extra stereo output?
Cheers,
Kjeld
