Same pedalboard as the previous one but now with a dry/wet chorus mix control, assigned to knob #1. To obtain a correct mix I used the "stereo x-fade" plugin with a gain plugin set to -3db in front of it to control the dry signal and another gain plugin after it set to +3db to compensate the losses of the "CS Chorus 2", The fade type on the "Stereo X-Fade" is set to "equal power". I also organised the pedals to better reflect the the saved pedalboard presets.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com//pedalboards/59cab4522564d468ef8f48ba
