Hey fellow Dwarfers (Dwarves?)
So I’m still very new to all things MOD/Dwarf and am learning lots as I go. I’m having an issue with my slightly extended DAW setup and I was wondering if anybody here has experienced something similar; and if so, whether I might ask for some recommendations on how to resolve this.
First of all, let me get this disclaimer/caveat out of the way: I don’t think there is any problem or issue with the Dwarf itself whatsoever; I’m surmising that my issue has something to do with setting levels between different interfaces. It seems to me that ‘the devil is in the details’ within any degree of sophisticated signal chain, so I’m sure there are just some settings I need to deal with.
So let me explain my conundrum:
When running my virtual rig most simply (electric bass, via Darkglass Clean Bass Preamp and Ernie Ball EVP volume pedal, into Input 1 of the Dwarf, headphones into Dwarf headphone jack, and USB connected to PC to enable access to local pedalboard GUI), everything is hunky-dory; runs perfectly, sounds great. No ground loop issues.
When I run a cable from the Output jack of the Dwarf into the Input jack of my Focusrite Scarlett 2i2 (thence into my PC into Ableton Live 10), I suddenly have the potential to hear all sorts of extreme noise and/or unwanted distortion. Now, from twiddling some knobs, etc. I’ve noticed a few things already. Firstly, pushing on the INST (instrument input) button on the front panel of the Scarlett seems to boost the signal way too much, whereas deselecting that resolves some (but not all) of that. I don’t have this problem at all when simply plugging my bass direct to the Focusrite. Secondly, I need to dial back the input gain on the Focusrite to about half the level I have it at when playing into the Focusrite without the Dwarf in the chain. Thirdly, any effects rack in Ableton has to be turned off or deleted, especially a compressor or limiter or amp/cabsim (OK, no problem there; with my new Dwarf, I shouldn’t need Ableton’s FX on the input channel anyway). Fourthly, I need to play my bass fairly gently; any aggressive fingerpicking or chords can trigger some clip, even with levels down low. I should mention that I’ve also checked to make sure that none of the obvious factors, such as channel levels within Ableton, could be causing these issues; they’re all set properly and Ableton shows no signs of input clipping after doing all of the above. I’ve also gone into Settings on the Dwarf and dropped the Output levels to 50% or less.
So I guess what I’m saying is, that compared to playing my bass through my simple Scarlett-PC-Ableton setup without the Dwarf, I have no issues with noise or unwanted distortion. Conversely, the Dwarf runs perfectly when not connected to my Focusrite box. But when introducing the Focusrite into the Dwarf signal chain, I have to be EXTREMELY careful with input levels, as the potential to overload the signal chain suddenly seems to skyrocket.
I have no doubt that all of this is a reflection of my technically unsopshiticated newbie level of experience and knowledge and somebody out there might be able to advise me about something to do with impedance or something. If you have any advice as to how I might optimize my setup even further to eliminate this noise and distortion I’m describing, that would be much appreciated. Maybe there’s a different alternative to the Focusrite for getting my Dwarf output into Ableton on my PC (???). Have any of you using a similar setup experienced any of these issues?
All that said, I remain totally impressed and inspired what this amazing box and software are capable of doing - loving the Dwarf!
Thanks
Frank in Vancouver
