I do see some people using the Alo looper, which seems to do what I am looking for, but I have not been able to find it on the Dwarf plugin store. Can someone help me with this?
Hi @DaybridgeGhost,
ALO should still be in beta. In the store you can activate a view to see all beta plugins.
At least, that did it for me
BR
Yes. It is in beta. @DaybridgeGhost you should activate it on the Advanced Settings of the WebGUI
Thank you! I was able to load it up, but having some trouble with using it.
For instance, how do I toggle between free-running and sync mode? I can’t hear the clicks even when the click volume is set to 10 so I am assuming i am stuck in free-running mode.
Also, when I set the reset mode to 3, the descriptions says double tapping a button should erase just that loop, but it seems to stop all loops.
The author has been quite helpful on the forums, I totally appreciate this plug in.
Possibly check his threads?
I’m not super familiar with the plugin myself, but there are a few things that are probably not yet super stable and that’s why the plugin is still in beta.
Thanks!
