It may be helpful for troubleshooting purposes to put a user-accessible option in the ‘system’ menu to dump boot logs and a summary of current system settings.
For example, with the input clipping issue currently being researched, this would give you access to compare a lot of different user data to try to trace it down to common settings or boot errors.
It could be an option in the “System” settings screen, and create a text file on the device that can be easily transferred by the user via USB connection.
Just an idea, which may or may not be useful for troubleshooting issues.
I’m aware but a simple dump script would enable the collection of debugging data without relying on the users technical ability. Streamlining that process seems like it would have some utility and shouldn’t be trying complex to implement…
