Any chance of being able to filter the existing plugin lists to only show ones which support tap tempo? That would be better than having to check the forums for a hand-curated list which presumably is at risk of going out of date as plugins develop. By “existing plugin lists”, I mean either/both of https://pedalboards.moddevices.com/plugins and the plugin list in the device’s web UI.
Well, I’d say there is not really a need for that, since…
You cannot use tap-tempo with plugins anymore, since v1.8.
It makes a lot more sense to map tempo related units.
We did not have this before, but now that we do, we went ahead and took out the plugins’ tap-tempo options.
Now, listing the plugins that have tempo-mappable parameters would indeed be useful.
How to present such “filters” is the question. Because once we add one, we will want more
Hi @Cato ! There is a built-in tuner that is accessible by pressing the two left footswitches simultaneously. Actually, you can also set global tempo there as well. But, I believe you can assign a footswitch to do tap tempo for a specific plugin.
