greetings!
wondering if there’s any way of getting a list of all the control chain and MIDI assignments in a particular pedalboard… even if it just exists as some file i can in the MOD find and grep or somesuch.
greetings!
If you want to check them out manually… the controller and control chain assignments are saved in /root/.pedalboards/< pedal >/addressings.json.
The MIDI CC ones are saved in the main pedalboard file.
cool… very helpful, thanks!
can these files be edited directly (i.e. to change current or make new MIDI assignments)?
also, we should not be able to assign a single MIDI controller to more than one plugin parameter, right? i’m looking at a pedalboard .ttl file right now which shows channel 1, controller 1 assigned to 2 different plugin parameters. yet, in the browser gui (and in actual functionality), only one of those assignments shows. am i misunderstanding or misreading? these two snippets appear in the .ttl file:
<kuiza_1/Level>
ingen:value 0.976378 ;
midi:binding [
midi:channel 1 ;
midi:controllerNumber 1 ;
lv2:minimum 0.000000 ;
lv2:maximum 1.000000 ;
a midi:Controller ;
<xfade/xfade>
ingen:value 1.000000 ;
midi:binding [
midi:channel 1 ;
lv2:minimum -1.000000 ;
a midi:Controller ;
…only the xfade one is active in the pedalboard.
MIDI was designed to allow a single controller to adjust multiple values.
I do this a lot in my techno/ambient compositions.
So I would not limit assignments and at the most put up a reminder that the control number is already assigned so you can choose to continue/ change
