Followed instructions given here
Despite existing a /data/enable-netmanager file, when I run systemctl list-unit-files jack-netmanager.service will show as disabled (that being after a reboot).
How to reproduce
ssh into mod
touch /data/enable-netmanager
reboot mod
Expected/suggested solution
running systemctl list-unit-files should present jack-netmanager.service as enabled.
Additional information
Open the controller menu (hold left knob down), navigate to Info > Versions and write down here the versions.
release: v1.10.1
controller: F017FF5
It is described on the same page you linked above.
Still to be considered experimental, but yes the target is a MOD unit acting as USB sound card.
(This is sadly broken in v1.10.1 due to a small mishap on my side, tested on Dwarf but forgot to check Duo/Duo X.)
If you want to try it out, I can give you a fixed v1.10.1 build.
I tried using the usb gadget method, Sink input/output appeared but I couldn’t get any sound from it (maybe because Im on windows?). Net manager method worked with jack on windows
So I had a look at this. The netmanager issue on Duo is not possible to fix without breakage.
Either it works for units with old 3.4 kernel, or works for units with 5.4 kernel, can’t be both at the same time.
Since this is clearly labelled EXPERIMENTAL in the settings, we will leave it as-is.
You can run these commands on a 5.4 kernel Duo to manually fix things: (but will revert and have to be re-run on next update)
mount / -o remount,rw
systemctl enable jack-netmanager.service
mount / -o remount,ro
kinda… but I have seen too many issues to make it worthwhile.
current releases of JACK use packed data structures on x86/64 platforms, but unpacked on ARM (packed is wanted in general, but causes issues with memory alignment on ARM systems).
the difference means that connecting regular x86/64 JACK to the one inside the MOD units (that uses ARM) will lead to random issues due to network packets not following the same exact data structure.
even when both are aligned, I still see occasional issues. so honestly I am for just removing this experimental option altogether.
the push for usb audio interface support seems a much better use of time and efforts, and one that allows usage from any system not just ones running JACK.
