Is many to one control mapping possible?
Apologies if this is obvious but I can’t seem to figure it out or find a related forum post…
I want to map two different, physical buttons (one momentary and one toggle) to the same parameter, is this possible?
Not directly. It is sometimes possible to use CV plugins for example to map two different physical buttons to the Control to CV - MOD Audio plugin and then combine the resulting signals with the Logic Operators - MOD Audio in XOR mode and then use that to control the destination plugin parameter. I say sometimes because not all parameters can be controlled via CV.
See also CV Tutorial - MOD Wiki
If you are using a MIDI controller it may be possible to do something clever using the infamous mindi - MOD Audio plugin.
Have a look at this plugin.
It provides an array of 5 pairs of buttons, each pair controlling a cv output. You can map each button to a different control and each cv output to plugin parameters
@Zavorra @pslh Will def check that out, thanks!
