I´m wondering if anyone else have this issue with the IR loader Cabsim.
Today I decided to update all my plugins and now the previously fine IR´s are now unusable.
I deleted the IR´s on the file manager and re-uploaded and this made no difference.
Also the load on the CPU is much harder. To the point that I needed to strip down the pedalboard in question.
Most likely this was caused by the IR Loader update.
We are checking if it’s worth leaving some options that allow us to push down the CPU load (by reducing quality, etc.)
I´ve updated the IR Loader Cabsim to the latest 1.0-19. and the sound problem seems to be solved but the load on the CPU is still very high, so the pedalboard in question is no longer viable.
Is it feasible to lower the CPU usage while maintaining the sound quality for these type of plug-ins?
It looks like my DUO MOD will be obsolete before I can get my hands on my Dwarf and how long will Dwarf be up to the task in face of these CPU-hungry plugins?
Most likely it needs to be a trade-off between quality and CPU usage.
The only solution for that may be a switch that selects between better quality and lower CPU. Basically the old and the new version.
The Dwarf handles this fine. The Duo has admittedly some more trouble.
