Invada Delay Munge (sum L+R in) - MOD Devices
Invada
A wet only delay with munged delays, the pitch can be modulated by a lfo.
This is a companion discussion topic for the original entry at https://pedalboards.moddevices.com/plugins/aHR0cDovL2ludmFkYXJlY29yZHMuY29tL3BsdWdpbnMvbHYyL2RlbGF5L3N1bQ==
Remember this is a WET only pedal so if you want to hear your original sound also you will need to add dry paths that don’t pass through this pedal.
