Hi falkTX, I’ve experienced the same connection issues with the wiring in the latest build from the github actions. I don’t know how to send you logs cause I don’t have anything really, it just needs a double, sometime triple rewiring, it occours from the last plugin to the output channel usually. Even on startup, when it loads the latest pedalboard used, sometimes I ear one channel only, left or right, and I have to rewire. Regarding the midi, I’ve opened an issue on github, because I was not able to switch the pedalboards or the snapshot in windows. In Linux the snapshots work fine, but the pedalboards do not switch. I’ve dove some fixes myself in the past to the mod-ui, declaring two new variabes for the midi channels, you can see the mods I’ve done on github @ raidolo/mod-ui (sorry can’t post links right now) The only issue I had was about the pedalboard name, that when I switch the pedalboard via midi, does not get updated and I need to refresh the page (I’ve opened an issue on mod-ui for this). If I don’t do that, when you press save, something weird happen. You save the pedalboard on the previous pedalboard basically. So it’s a bit buggy. I really like to help on this, but I’m not a seasoned developer and I had some difficult times understanding all the pieces and where to modify to make the midi work…
for the MIDI there is a PR open that I still need to review and merge, related to this. It seems indeed the pedalboard/snapshot changes dont always work as intended.
on the needing multiple connections, I really thought I had that fixed already… I wonder if due to renaming of the program files folder you are still running an older version.
I will add a version to the main window, so it is clear which version of mod-app is installed and running.
I’m esperiencing the wiring issue on Linux, where I just downloaded the new app. No previous versions. It’s the build #87 from the actions. I’ve seen you did some more builds but I don’t see any change, do they contains the changes you mentioned?
I’ll have a look at the PR regarding the switching with midi, thanks.
oh, I only saw it on windows which was weird, makes sense to happen more generally yes.
sadly that makes it seem like I need to forget about some of the optimizations in place there…
can you retry and check if the issue is gone on windows for you? there is a dedicated workaround in place for windows where I saw this happen, but not for other systems.
Which build in particular? Is it ok to use #92? Oh another thing… to test the Midi would be useful to insert the Midi Display plugin in the build, It should work on Linux, not sure on Windows. Is there any fastest way to communicate with the team or participate actively? Discord perhaps?
you are communicating with the team :wink:
forums and github issues is the way to go, specially on github to track each individual issue separately.
on which build to use, just grab whatever was the last successful one.
I am putting in place automatic validation of plugins, to ensure we can at least load them without crashes. so there will be a few build failures until that is fully resolved.
I’ve done some tests on the Windows version, the audio connection seems consistent with the wiring. I’ve restarted the services multiple times and it never failed. The build is build #92: Commit [fa65bc6]. I don’t know if you changed something regarding midi, but now I’m able to switch the snapshots at least. I’ve noticed another thing, when I start the gui, it loads the snapshot the has been selected while saving the pedalboard. It’s ok, but all the plugins selection, for instance the NAM model, the IR in the IR loader, are empty. Then, if I load manually the snapshot again, they appear. It’s only cosmetic because the sounds match what’s contained in the snap.
Regarding the Linux version, same build as Windows Commit [fa65bc6], I have sound and channels inconsistency and I have to redo the wiring. The weird thing is that the Jack Graph is correct, the last plugin is stereo wired to the mod-monitor. Then I detach the not functioning cable, I see the missing connection in the graph, then I reconnect it back and at that moment I have full stereo out.
This is one of the quirks of windows vs posix paths, “\” vs “/”
Also windows not supporting symlinks, which LV2 kinda relies on to keep track of things proper.
It is very likely that on Windows we need to skip the whole “leave a link on pedalboard for easy sharing of files” thing, and always reference the original files instead…
Thanks for the windows vs linux testing, it confirms my suspicion of what is going on.
It is not nice, but at least I should be able to put up a workaround for that soon.
Still trying to get the plugins all validated and running. the neuralrecord was hopefully the last one, we got a nice collection now with the latest builds.
The GUI is getting a little more tweaks, now hiding away all the advanced stuff.
and with everything open
and then the logs too
With the exception of screcord, all plugins are building and passing a quick automated self-test.
Will do a bit more cleanup after the latest changes, then prepare for a release. Have a big event coming up (anyone going for the Ubuntu Summit in Latvia too?) so new release likely only next week.
Just wanted to share my experiences with the App:
First of all: it is really great!! I found myself quite often just plugging in my Guitar directly into my interface and using the Mod App instead of using my physical pedalboard with the dwarf, which is also directly connected to my audio interface. Especially using the AIDA-X models I surprisingly experienced a quite noticeable improvement of sound quality using directly my interface with the MOD App. I have to investigate a little more, but it’s maybe because of some “tone-sucking” pedals on my pedalboard, which alternate the sound quality quite hearable. Or could this be due to different A/D converters used in the dwarf and my interface? (Im definetly not an expert in this topic)
I also would appreciate some kind of easy DAW-integration of the Mod App. I tried to use it as an input for Ableton, but I haven’t managed it yet. How did you do this exactly @suitsus? Did you use ASIO drivers?
I’m really looking forward to the next build with more plugins. Thanks a lot @falkTX for developing this app!
I used the routing matrix in my audio interface, an iConnectivity iConnect AUDIO 4+.
I feel silly, is there something I’m missing? I’d like to try other amp sims but I don’t see how to select them. The AIDA-X panel shows “C:\Program Files\MOD App\plugins\rt-neural-generic.lv2\models\deer ink studios\tw40_california_clean_deerinkstudios.json”
and that directory shows several more, such as:
tw40_blues_deluxe_deerinkstudios.json
tw40_blues_solo_deerinkstudios.json
tw40_british_lead_deerinkstudios.json
tw40_british_rhythm_deerinkstudios.json
tw40_california_crunch_deerinkstudios.json
but how do I load one of them? Thanks!
Another small release after getting a lot of details sorted out:
Those that tested before and had issues, please try again.
In particular:
  • macOS and Windows WASAPI device options were not handled correctly, now fixed
  • pedalboard screenshots should work now
  • saving and loading pedalboards, presets and plugin files should finally be working properly on windows
  • fixed a few plugin crashes
  • fixed midi input on windows, was crashing on any event
  • fixed the weird connection issue not passing audio data sometimes
  • many more plugins added
  • added a linux build
there are still a few things to fix, adjust and implement. go to Issues · moddevices/mod-app · GitHub for the current list of tasks and issues/bugs.
your feedback would be very appreciated, thanks in advance!
(and a screenshot to finalize, because we always appreciate those)
and just noticed the linux build is broken… “works on my machine” sorta situation, local builds are ok but the one in the releases is not. fixing that soon, then tagging 0.0.4 after verifying that automated builds actually work.
falkTX…
there is somthing wrong in the last release (003). I’m not sure if the problem is on my site but…
I had the version 002 working without problem, but after installing the new version, after pressing the START button (with the same configuration of version 002) the button OPEN WEB GUI doesn’t light up. and if I try it manually it gave me an error Site not reaced. If I install the old version it works.
In the loggin window on MOD-UI:
Traceback (most recent call last):
  File ".\lib\__startup__.py", line 40, in run
  File ".\lib\Console.py", line 37, in run
  File "utils\cxfreeze\mod-ui-setup.py", line 11, in <module>
ModuleNotFoundError: No module named 'PIL'
In the loggin window on Jackd+host:
Starting jackd using:
-R -S -n mod-app -C .\jack\jack-session.conf -v -d portaudio -r 48000 -p 128 -P Windows WASAPI::Cuffie a due canali indipendenti (IDT High Definition Audio CODEC) -C Windows WASAPI::Array microfoni integrato (IDT High Definition Audio CODEC)
jackdmp 1.9.22
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2016 Grame.
Copyright 2016-2023 Filipe Coelho.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
Drivers/internals found in : C:\Program Files\MOD App
JACK server starting in realtime mode with priority 10
self-connect-mode is "Don't restrict self connect requests"
Jack: JackWinThread::StartImp : create non RT thread
Jack: JackWinThread::ThreadHandler : start
Jack: Initializing PortAudio...
Jack: JackPortAudioDriver::Open nframes = 128 in = 0 out = 0 capture name = Windows WASAPI::Array microfoni integrato (IDT High Definition Audio CODEC) playback name = Windows WASAPI::Cuffie a due canali indipendenti (IDT High Definition Audio CODEC) samp
Jack: JackDriver::Open capture_driver_name = Windows WASAPI::Array microfoni integrato (IDT High Definition
Jack: JackDriver::Open playback_driver_name = Windows WASAPI::Cuffie a due canali indipendenti (IDT High Defi
Jack: Check protocol client = 9 server = 9
Jack: JackEngine::ClientInternalOpen: name = system
Jack: JackEngine::AllocateRefNum ref = 0
Jack: JackWinSemaphore::Allocate name = jack_pipe.mod-app_system val = 0
Jack: JackEngine::NotifyAddClient: name = system
Jack: JackGraphManager::SetBufferSize size = 128
Jack: JackConnectionManager::DirectConnect first: ref1 = 0 ref2 = 0
Jack: JackGraphManager::ConnectRefNum cur_index = 0 ref1 = 0 ref2 = 0
Jack: JackDriver::SetupDriverSync driver sem in normal mode
Jack: JackPortAudioDriver::Open fInputDevice = 12, fOutputDevice 10
Jack: JackPortAudioDriver::Open setup max in channels = 2
Jack: JackPortAudioDriver::Open setup max out channels = 2
Jack: JackPortAudioDriver::OpenStream buffer_size = 128
Jack: JackWinNamedPipeServerChannel::Open
Jack: JackWinNamedPipeServer::BindAux : fName \\.\pipe\server_jack_mod-app_0
Jack: JackEngine::Open
Jack: JackWinNamedPipeClient::ConnectAux : fName \\.\pipe\server_jack_mod-app_0
Jack: JackEngine::ClientInternalOpen: name = freewheel
Jack: JackEngine::AllocateRefNum ref = 1
Jack: JackWinSemaphore::Allocate name = jack_pipe.mod-app_freewheel val = 0
Jack: JackEngine::NotifyAddClient: name = freewheel
Jack: JackDriver::ClientNotify ref = 1 driver = system name = freewheel notify = 0
Jack: JackDriver::ClientNotify ref = 0 driver = freewheel name = system notify = 0
Jack: JackConnectionManager::DirectConnect first: ref1 = 1 ref2 = 1
Jack: JackGraphManager::ConnectRefNum cur_index = 0 ref1 = 1 ref2 = 1
Jack: JackAudioDriver::Attach fBufferSize = 128 fSampleRate = 48000
Jack: JackEngine::PortRegister ref = 0 name = system:capture_1 type = 32 bit float mono audio flags = 22 buffer_size = 128
Jack: JackGraphManager::AllocatePortAux port_index = 1 name = system:capture_1 type = 32 bit float mono audio
Jack: JackConnectionManager::AddOutputPort ref = 0 port = 1
Jack: JackEngine::ClientNotify: no callback for notification = 9
Jack: JackAudioDriver::Attach fCapturePortList[i] port_index = 1
Jack: JackEngine::PortRegister ref = 0 name = system:capture_2 type = 32 bit float mono audio flags = 22 buffer_size = 128
Jack: JackGraphManager::AllocatePortAux port_index = 2 name = system:capture_2 type = 32 bit float mono audio
Jack: JackConnectionManager::AddOutputPort ref = 0 port = 2
Jack: JackAudioDriver::Attach fCapturePortList[i] port_index = 2
Jack: JackEngine::PortRegister ref = 0 name = system:playback_1 type = 32 bit float mono audio flags = 21 buffer_size = 128
Jack: JackGraphManager::AllocatePortAux port_index = 3 name = system:playback_1 type = 32 bit float mono audio
Jack: JackConnectionManager::AddInputPort ref = 0 port = 3
Jack: JackAudioDriver::Attach fPlaybackPortList[i] port_index = 3
Jack: JackEngine::PortRegister ref = 0 name = system:playback_2 type = 32 bit float mono audio flags = 21 buffer_size = 128
Jack: JackGraphManager::AllocatePortAux port_index = 4 name = system:playback_2 type = 32 bit float mono audio
Jack: JackConnectionManager::AddInputPort ref = 0 port = 4
Jack: JackAudioDriver::Attach fPlaybackPortList[i] port_index = 4
Jack: InitTime : multimedia timer resolution set to 1 milliseconds
Jack: JackServer::Start
Jack: JackPortAudioDriver::Start
Jack: JackWinNamedPipeServerChannel::Init
Jack: JackWinNamedPipeServerChannel::ClientAdd size 0
Jack: JackLoadableInternalClient::JackLoadableInternalClient path_to_so = jack/mod-midi-merger.dll
Jack: No jack_get_descriptor entry-point for mod-midi-merger
Jack: JackInternalClient::Open name = mod-midi-merger
Jack: JackEngine::ClientInternalOpen: name = mod-midi-merger
Jack: JackEngine::AllocateRefNum ref = 2
Jack: JackWinSemaphore::Allocate name = jack_pipe.mod-app_mod-midi-merger val = 0
Jack: JackEngine::NotifyAddClient: name = mod-midi-merger
Jack: JackClientPipeThread::Execute ebf3bdc0
Jack: JackDriver::ClientNotify ref = 2 driver = system name = mod-midi-merger notify = 0
Jack: JackRequest::Notification
Jack: JackClient::ClientNotify ref = 0 name = system notify = 0
Jack: JackDriver::ClientNotify ref = 2 driver = freewheel name = mod-midi-merger notify = 0
Jack: JackClient::ClientNotify ref = 1 name = freewheel notify = 0
Jack: JackClient::SetupDriverSync driver sem in normal mode
Jack: JackInternalClient::Open name = mod-midi-merger refnum = 2
Jack: JackDriver::ClientNotify ref = 1 driver = freewheel name = freewheel notify = 18
Jack: JackEngine::PortRegister ref = 2 name = mod-midi-merger:in type = 8 bit raw midi flags = 1 buffer_size = 0
Jack: JackGraphManager::AllocatePortAux port_index = 5 name = mod-midi-merger:in type = 8 bit raw midi
Jack: JackConnectionManager::AddInputPort ref = 2 port = 5
Jack: JackClient::PortRegister ref = 2 name = mod-midi-merger:in type = 8 bit raw midi port_index = 5
Jack: JackEngine::PortRegister ref = 2 name = mod-midi-merger:out type = 8 bit raw midi flags = 2 buffer_size = 0
Jack: JackGraphManager::AllocatePortAux port_index = 6 name = mod-midi-merger:out type = 8 bit raw midi
Jack: JackConnectionManager::AddOutputPort ref = 2 port = 6
Jack: JackClient::PortRegister ref = 2 name = mod-midi-merger:out type = 8 bit raw midi port_index = 6
Jack: JackEngine::ClientNotify: no callback for notification = 4
Jack: JackClient::Activate
Jack: JackClient::kBufferSizeCallback buffer_size = 128
Jack: JackClient::Init : period = 0 computation = 0 constraint = 0
Jack: JackWinThread::AcquireRealTimeImp priority = 7
Jack: JackWinProcessSync::Trylock WaitForSingleObject err = 0
Jack: JackEngine::ClientActivate ref = 2 name = mod-midi-merger
Jack: JackConnectionManager::DirectConnect first: ref1 = 1 ref2 = 2
Jack: JackGraphManager::ConnectRefNum cur_index = 1 ref1 = 1 ref2 = 2
Jack:: JackConnectionManager::DirectConnect first: ref1 = 2 ref2 = 1
Jack: JackGraphManager::ConnectRefNum cur_index = 1 ref1 = 2 ref2 = 1
Jack: JackClient::ClientNotify ref = 2 name = mod-midi-merger notify = 2
Jack: JackClient::kActivateClient name = mod-midi-merger ref = 2
Jack: JackClient::ClientNotify ref = 2 name = mod-midi-merger notify = 9
Jack: JackClient::kPortRegistrationOn port_index = 5
Jack: JackClient::kPortRegistrationOn port_index = 6
Internal client mod-midi-merger successfully loaded
Jack: JackLoadableInternalClient::JackLoadableInternalClient path_to_so = jack/mod-midi-broadcaster.dll
Jack: No jack_get_descriptor entry-point for mod-midi-broadcaster
Jack: JackInternalClient::Open name = mod-midi-broadcaster
Jack: JackEngine::ClientInternalOpen: name = mod-midi-broadcaster
Jack: JackEngine::AllocateRefNum ref = 3
Jack: JackWinSemaphore::Allocate name = jack_pipe.mod-app_mod-midi-broadcaster val = 0
Jack: JackEngine::NotifyAddClient: name = mod-midi-broadcaster
Jack: JackDriver::ClientNotify ref = 3 driver = system name = mod-midi-broadcaster notify = 0
Jack: JackDriver::ClientNotify ref = 3 driver = freewheel name = mod-midi-broadcaster notify = 0
Jack: JackClient::ClientNotify ref = 2 name = mod-midi-merger notify = 18
Jack: JackClient::ClientNotify ref = 3 name = mod-midi-broadcaster notify = 0
Jack: JackClient::kAddClient fName = mod-midi-merger name = mod-midi-broadcaster
Jack: JackClient::ClientNotify ref = 2 name = mod-midi-merger notify = 0
Jack: JackInternalClient::Open name = mod-midi-broadcaster refnum = 3
Jack: JackEngine::PortRegister ref = 3 name = mod-midi-broadcaster:in type = 8 bit raw midi flags = 1 buffer_size = 0
Jack: JackGraphManager::AllocatePortAux port_index = 7 name = mod-midi-broadcaster:in type = 8 bit raw midi
Jack: JackConnectionManager::AddInputPort ref = 3 port = 7
Jack: JackClient::PortRegister ref = 3 name = mod-midi-broadcaster:in type = 8 bit raw midi port_index = 7
Jack: JackEngine::PortRegister ref = 3 name = mod-midi-broadcaster:out type = 8 bit raw midi flags = 2 buffer_size = 0
Jack: JackGraphManager::AllocatePortAux port_index = 8 name = mod-midi-broadcaster:out type = 8 bit raw midi
Jack: JackConnectionManager::AddOutputPort ref = 3 port = 8
Jack: JackClient::PortRegister ref = 3 name = mod-midi-broadcaster:out type = 8 bit raw midi port_index = 8
Jack: MMCSS API not used...
Jack: JackEngine::ClientActivate ref = 3 name = mod-midi-broadcaster
Jack: JackConnectionManager::DirectConnect first: ref1 = 1 ref2 = 3
Jack: JackGraphManager::ConnectRefNum cur_index = 3 ref1 = 1 ref2 = 3
Jack: JackConnectionManager::DirectConnect first: ref1 = 3 ref2 = 1
Jack: JackGraphManager::ConnectRefNum cur_index = 3 ref1 = 3 ref2 = 1
Jack: JackClient::ClientNotify ref = 3 name = mod-midi-broadcaster notify = 2
Jack: JackClient::kActivateClient name = mod-midi-broadcaster ref = 3
Jack: JackClient::kPortRegistrationOn port_index = 7
Jack: JackClient::ClientNotify ref = 3 name = mod-midi-broadcaster notify = 9
Jack: JackClient::kPortRegistrationOn port_index = 8
Internal client mod-midi-broadcaster successfully loaded
Jack: JackClient::ClientNotify ref = 3 name = mod-midi-broadcaster notify = 18
Jack: JackLoadableInternalClient::JackLoadableInternalClient path_to_so = jack/mod-host.dll
Jack: No jack_get_descriptor entry-point for mod-host
Jack: JackInternalClient::Open name = mod-host
Jack: JackEngine::ClientInternalOpen: name = mod-host
Jack: JackEngine::AllocateRefNum ref = 4
Jack: JackWinSemaphore::Allocate name = jack_pipe.mod-app_mod-host val = 0
Jack: JackEngine::NotifyAddClient: name = mod-host
Jack: JackDriver::ClientNotify ref = 4 driver = system name = mod-host notify = 0
Jack: JackDriver::ClientNotify ref = 4 driver = freewheel name = mod-host notify = 0
Jack: JackClient::ClientNotify ref = 4 name = mod-host notify = 0
Jack: JackClient::kAddClient fName = mod-midi-merger name = mod-host
Jack: JackClient::kAddClient fName = mod-midi-broadcaster name = mod-host
Jack: JackInternalClient::Open name = mod-host refnum = 4
Jack: JackEngine::PortRegister ref = 4 name = mod-host:midi_in type = 8 bit raw midi flags = 1 buffer_size = 0
Jack: JackGraphManager::AllocatePortAux port_index = 9 name = mod-host:midi_in type = 8 bit raw midi
Jack: JackConnectionManager::AddInputPort ref = 4 port = 9
Jack: JackClient::PortRegister ref = 4 name = mod-host:midi_in type = 8 bit raw midi port_index = 9
Jack: jack_client_open mod-monitor
Jack: JackInternalClient::Open name = mod-monitor
Jack: JackEngine::ClientInternalOpen: name = mod-monitor
Jack: JackEngine::AllocateRefNum ref = 5
Jack: JackWinSemaphore::Allocate name = jack_pipe.mod-app_mod-monitor val = 0
Jack: JackEngine::NotifyAddClient: name = mod-monitor
Jack: JackDriver::ClientNotify ref = 5 driver = system name = mod-monitor notify = 0
Jack: JackDriver::ClientNotify ref = 5 driver = freewheel name = mod-monitor notify = 0
Jack: JackClient::ClientNotify ref = 5 name = mod-monitor notify = 0
Jack: JackClient::kAddClient fName = mod-midi-merger name = mod-monitor
Jack: JackClient::kAddClient fName = mod-midi-broadcaster name = mod-monitor
Jack: JackInternalClient::Open name = mod-monitor refnum = 5
Jack: JackEngine::PortRegister ref = 5 name = mod-monitor:in_1 type = 32 bit float mono audio flags = 1 buffer_size = 0
Jack: JackGraphManager::AllocatePortAux port_index = 10 name = mod-monitor:in_1 type = 32 bit float mono audio
Jack: JackConnectionManager::AddInputPort ref = 5 port = 10
Jack: JackClient::PortRegister ref = 5 name = mod-monitor:in_1 type = 32 bit float mono audio port_index = 10
Jack: JackEngine::PortRegister ref = 5 name = mod-monitor:in_2 type = 32 bit float mono audio flags = 1 buffer_size = 0
Jack: JackGraphManager::AllocatePortAux port_index = 11 name = mod-monitor:in_2 type = 32 bit float mono audio
Jack: JackConnectionManager::AddInputPort ref = 5 port = 11
Jack: JackClient::PortRegister ref = 5 name = mod-monitor:in_2 type = 32 bit float mono audio port_index = 11
Jack: JackEngine::PortRegister ref = 5 name = mod-monitor:out_1 type = 32 bit float mono audio flags = 2 buffer_size = 0
Jack: JackGraphManager::AllocatePortAux port_index = 12 name = mod-monitor:out_1 type = 32 bit float mono audio
Jack: JackConnectionManager::AddOutputPort ref = 5 port = 12
Jack: JackClient::PortRegister ref = 5 name = mod-monitor:out_1 type = 32 bit float mono audio port_index = 12
Jack: JackEngine::PortRegister ref = 5 name = mod-monitor:out_2 type = 32 bit float mono audio flags = 2 buffer_size = 0
Jack: JackGraphManager::AllocatePortAux port_index = 13 name = mod-monitor:out_2 type = 32 bit float mono audio
Jack: JackConnectionManager::AddOutputPort ref = 5 port = 13
Jack: JackClient::PortRegister ref = 5 name = mod-monitor:out_2 type = 32 bit float mono audio port_index = 13
Jack: jack_set_graph_order_callback ext_client ebf52f00 client ebf52f00
Jack: JackEngine::ClientActivate ref = 5 name = mod-monitor
Jack: JackConnectionManager::DirectConnect first: ref1 = 1 ref2 = 5
Jack: JackGraphManager::ConnectRefNum cur_index = 4 ref1 = 1 ref2 = 5
Jack: JackConnectionManager::DirectConnect first: ref1 = 5 ref2 = 1
Jack: JackGraphManager::ConnectRefNum cur_index = 4 ref1 = 5 ref2 = 1
Jack: JackClient::ClientNotify ref = 5 name = mod-monitor notify = 2
Jack: JackClient::kActivateClient name = mod-monitor ref = 5
Jack: JackClient::kPortRegistrationOn port_index = 10
Jack: JackClient::ClientNotify ref = 5 name = mod-monitor notify = 18
Jack: JackClient::kPortRegistrationOn port_index = 11
Jack: JackClient::kPortRegistrationOn port_index = 12
Jack: JackClient::kPortRegistrationOn port_index = 13
Jack: JackClient::Connect src = mod-monitor:out_1 dst = system:playback_1
Jack: JackClient::ClientNotify ref = 5 name = mod-monitor notify = 4
Jack: JackEngine::PortConnect ref = 5 src = mod-monitor:out_1 dst = system:playback_1
Jack: JackClient::kGraphOrderCallback
Jack: WaitGraphChange...
Jack: JackGraphManager::CheckConnect src_name = mod-monitor:out_1 dst_name = system:playback_1
Jack: JackEngine::PortConnect ref = 5 src = 12 dst = 3
Jack: JackGraphManager::Connect port_src = 12 port_dst = 3
Jack: JackConnectionManager::Connect port_src = 12 port_dst = 3
Jack: JackConnectionManager::Connect port_src = 3 port_dst = 12
Jack: JackConnectionManager::IsLoopPathAux ref1 = 0 ref2 = 5
Jack: JackConnectionManager::DirectConnect first: ref1 = 5 ref2 = 0
Jack: JackConnectionManager::IncConnectionRef: ref1 = 5 ref2 = 0
Jack: JackEngine::ClientNotify: no callback for notification = 11
Jack: JackClient::Connect src = mod-monitor:out_2 dst = system:playback_2
Jack: JackEngine::PortConnect ref = 5 src = mod-monitor:out_2 dst = system:playback_2
Jack: JackGraphManager::CheckConnect src_name = mod-monitor:out_2 dst_name = system:playback_2
Jack: JackEngine::PortConnect ref = 5 src = 13 dst = 4
Jack: JackGraphManager::Connect port_src = 13 port_dst = 4
Jack: JackConnectionManager::Connect port_src = 13 port_dst = 4
Jack: JackConnectionManager::Connect port_src = 4 port_dst = 13
monitor debug: out1 connected: false, out2 connected: false
Jack: jack_set_thread_init_callback ext_client ebf3f300 client ebf3f300
Jack: new timebase master: ref = 4
Jack: JackClient::Init calling client thread init callback
Jack: JackEngine::ClientActivate ref = 4 name = mod-host
Jack: JackConnectionManager::DirectConnect first: ref1 = 1 ref2 = 4
Jack: JackGraphManager::ConnectRefNum cur_index = 6 ref1 = 1 ref2 = 4
Jack: JackConnectionManager::DirectConnect first: ref1 = 4 ref2 = 1
Jack: JackGraphManager::ConnectRefNum cur_index = 6 ref1 = 4 ref2 = 1
Jack: JackClient::ClientNotify ref = 4 name = mod-host notify = 2
Jack: JackClient::kActivateClient name = mod-host ref = 4
Jack: JackClient::kPortRegistrationOn port_index = 9
Jack: JackClient::ClientNotify ref = 4 name = mod-host notify = 9
Jack: JackClient::Connect src = mod-midi-merger:out dst = mod-host:midi_in
Jack: JackEngine::PortConnect ref = 4 src = mod-midi-merger:out dst = mod-host:midi_in
Jack: JackGraphManager::CheckConnect src_name = mod-midi-merger:out dst_name = mod-host:midi_in
Jack: JackEngine::PortConnect ref = 4 src = 6 dst = 9
Jack: JackGraphManager::Connect port_src = 6 port_dst = 9
Jack: JackConnectionManager::Connect port_src = 6 port_dst = 9
Jack: JackConnectionManager::Connect port_src = 9 port_dst = 6
Jack: JackConnectionManager::IsLoopPathAux ref1 = 4 ref2 = 2
Jack: JackConnectionManager::IsLoopPathAux ref1 = 1 ref2 = 2
Jack: JackConnectionManager::DirectConnect first: ref1 = 2 ref2 = 4
Jack: JackConnectionManager::IncConnectionRef: ref1 = 2 ref2 = 4
Jack: JackClient::ClientNotify ref = 4 name = mod-host notify = 18
Internal client mod-host successfully loaded
I have the same problems like @Rino2 … its not possible to start mod-gui with the 0.0.3 on windows 10… the 0.0.2 version worked without problems
ok seems windows version is also broken, sorry for that.
but this is why we want to have automated builds, so that once fixed it will be reproducible.
likely due to the same issue as the linux builds.
do the macOS ones even work then?
just downloaded… it starts up and sees all my audio I/O.
haven’t gone any further yet.
thanks, I verified the same too. on the windows side I found the issue, already fixed in the latest automated builds, now to try to fix the linux side too…
