Just checked kaspersky’s register and sure enough you were right! Those files were flagged as trojan and deleted even though kaspersky didn’t show any notifications about it. Thanks a lot!
This is pretty awesome, my only problem is that I’m on an ARM laptop running linux. I see that the source is available on github but there are no build instructions for it. Is there a chance that it can be added?
It seems that it no longer works on Linux since Pipewire was updated to 1.2.0.
Does anyone know if the Mod plugin version for DAW’s is under construction yet?
And is there an estimated time when it would be ready?
Updated to ubuntu 24.04.1 from 22.04 and CPU usage has increased a lot in pipe/wire and direct to interface (mod jack) configuration. Not sure why it’s happening but I have some xruns now.
Found the problem, CPU Governor
Is Mod Desktop supposed to support integrate [dot] moddevices [dot] com?
If not, is this on the roadmap?
it does not support it yet, but it is in the plans yet.
though first it needs to support integration with the plugin store, and that first needs having desktop builds online.
so realistically not happening this year, but hopefully we see advances for that in the next
The Desktop version is running nicely on my Macbook Pro. CPU load is reasonable, lots of fun incorporating it into my guitar rig.
I have some issues using Midi though. CCs for controlling certain plugins work like charm. But I cannot figure out how to do Pedalboard Changes.
According to the wiki, it should be able to do so using PC commands. I tried everything with different settings in the Midi Setup, but I cannot get Pedalboard or Snapshots to change. Should this work on version 0.0.12?
It’s also kind of lost because the Logging doesn’t show anything suspicious, and also I cannot find any plugin that would support monitoring incoming MIDI messages.
Help would me much appreciated here.
I checked again, all I see in the logging are these entries whenever I send CC commands:
DEBUG: effects_output_data_ready() UI is ready to receive more stuff (code 0)
DEBUG: RunPostPonedEvents() START
DEBUG: RunPostPonedEvents() Queue is empty
DEBUG: PostPonedEventsThread() looping (code 1)
PROTOCOL: response 'resp 0'
DEBUG: RunPostPonedEvents() Before the queue iteration
DEBUG: RunPostPonedEvents() Sending 'param_set 0 :bypass 1.000000'
DEBUG: RunPostPonedEvents() After the queue iteration
DEBUG: RunPostPonedEvents() Sending 'data_finish'
DEBUG: RunPostPonedEvents() END
Whats odd is that I cannot see such entries when I try to send PC commands - regardless of the channel I am using. I tried with another software and confirm that PC commands are properly sent (e.g. C0 00, where I would assume that the first pedalboard is being loaded). “MIDI Program Channel for pedalboard” is set to 1.
Hello, very appy, I’ve just discovered the app version, looking for futur investment in the pedal version. However, I’m using a M1 macbook air, and an antelope audio interface. I can get the sound out from MOD but can’t get my bass in…Any suggestion? tell me if you some more specific infos.
No problem for me with my black lion audio interface and my macbook m3. I would even say that the sound quality is excellent.
Can you take a screenshot of the mod configuration window?
The short answer is: yes.
The long answer is that there are a lot of links, pretty much one per plugin. When you click on the info button on top of each plugin, you get to a page where there’s a Home Page link. There, likely, you will find your way to download the plugin. Good luck
in linux there are in:
mod-desktop-0.0.12-linux-x86_64/mod-desktop/plugins/
asuming mod-desktop-0.0.12-linux-x86_64 is the directory where you untar it.
Hi everyone,
today I checked to see if there were any updates to Mod Desktop and, more importantly, if there was a stable version available…
I noticed that Mod Desktop hasn’t been updated since March 12, 2024 — which means it’s been over a year. I thought we had finally reached a stable and official release, but it turns out we’re still in beta.
Given this long period of silence, I assume the project has been abandoned…
Am I wrong?
The last release was a year ago, but there has been development on the project as late as last month.
The MOD team has been very busy with other projects the past year and it will take some time before MOD Desktop can get some proper attention again.
The MOD team has been doing fantastic work from the very beginning. I’m impressed with the degree of continuity given all the obstacles they’ve encountered.
Commendable persistance!
I found MOD Audio renewed https://mod.audio/ site, which provides information about MOD Dwarf and MOD Desktop.
By the way, if you use Linux version of MOD Desktop, you can add some plugins with mod-plugin-builder.
Thank you for your feedback, MOD Desktop is a very powerful tool and a great project…i really hope it will be updated asap ![]()
