I have built customizations of the Sooperlooper plugin. I would like to install these modifications on my device. I have followed the instructions and used both the mod-sdk UI to install my new version and curl with the following command
tar cz sooperlooper.lv2 | base64 | curl -F 'package=@-' http://192.168.51.1/sdk/install
Both methods fail. The first has no response and no log output. The second does not finish. Using these two installation methods also breaks the existing Sooperlooper plugin until I reboot the unit.
Do I have to enable the mod-sdk on the device as implied in
I haven’t figured out the Tornado app’s bug which prevents publishing, but I did figure out a manual procedure. Updated wiki docs.
