Impossible to reinstall system
Description
MOD DUO (NAND, SN: MDS-20180601-1-02-003-0043)
I’m trying to reinstall the system. I follow instructions:
  • boot-fel-factory-reset seems ok, but not always the Duo enters in recovery mode (often it freezes on startup logo, but I can see it in Mac Finder and copy Factory-Reset-Image on)
  • If Duo enters in Recovery mode, reinstalling Factory-Reset-Image seems ok
  • In any case, when the machine reboots it freezes on startup logo and doesn’t works at all.
    Trying again (and again and again…) it gives always the same problems.
Booting while pressing left knob and foot switch doesn’t work.
SSH doesn’t work.
USB Ethernet device is not provided
Any idea?
Does it ever recognize on the computer as a storage device?
always, after boot-fel-factory-reset
Effectively: it is recognized as a storage device ONLY after a boot-fel-factory-reset.
Otherwise it is not recognized as a storage device.
It seems Duo remains in FEL mode.
Whenever I power it on and connect to computer, I can run boot-fel script. After it has finished, Duo appears as a storage device. And then:
  • Mostly, screen is frozen on logo and no led is turned on. I can copy system-image on it but when I remove mass storage and unplug USB cable, nothing happens.
  • Rarely, it enters Recovery mode (sometimes only leds works, lcd is steel frozen), I copy system-image, installation seems to work (less pass from blue to red to green), but when machine reboots it freeze on the logo (it seems to be in FEL mode)
I assume you are following these steps, right?
Is your Duo a NAND unit? Check it here
  • yes
  • yes
Ok.
Can you please write us at support@moddevices.com?
Please link this thread since you already shared a lot of info here :slight_smile:
Most likely your device will need some repair. As soon as you write us there I will try to process it asap
Hi Joao,
I wrote you some emails but I received no answer. Please can you send me a feedback?
Thanks
Hello Guido,
If you did write last week, I was in vacation and didn’t manage to read it.
I will get back to you there asap.
Thanks for understanding.
