Hey I solved my problem where I couldn’t login to mod duo web interface before, but I haven’t been using the device for a while and now I have the same problem again can anyone help me, when I login it sais You can’t reach this
Website)
Are you connected with bluetooth or USB ?
Which brother do you use ?
The message you show appears when you hit http://192.168.51.1 ? Or http://192.168.50.1 ?
I’ve often had trouble connecting (both Duo and Dwarf) but what seems to work is:
- Make sure the computer is on
- Connect the USB cable
- Power up the MOD device
- Once fully booted and you see the pedalboard loaded, then try to connect
