Thanks for noticing, fixed now again.
Since this is a public instance, it can sometimes be put in a locked state. I added a rule to auto-restart every 24h now, so at maximum we need to wait for the next day to use it again.
I have been trying to play the audio files in try.mod.audio, but I never get any sound even after enabling streaming. I love the idea of being able to try out pedals to find the sounds I am looking for without having to have a guitar or a mod device in my hands. I am using a Macbook Pro M1 2020 running Ventura 13.1. I’ve tried both Chrome and Safari with the same results…no sound. Is there something else I need to enable or a setting I might need to change?
I have several plugins in Chrome, but none in Safari. I’ll try FireFox though. I am at a school that has a pretty good firewall and content filtering protocol that might be interfering as well. I’ll let you know how it goes.
The sound comes through WebRTC which uses random ports in the 16000-32000 range, easily blocked on the network level. Browser console can tell/report if such requests are being blocked.
Nothing on Firefox. I’ll try at home next. I get audio from YouTube and other audio sources online, but maybe I need to add mod audio to our allowed list for content.
Failed to load resource: the server responded with a status of 404 (Not Found)
manifest.json:1 Manifest: Line: 1, column: 1, Syntax error.
mod-ui.js?v=1678463112:215 Audio playback start
try.mod.audio/:1 Uncaught (in promise) Error: A listener indicated an asynchronous response by returning true, but the message channel closed before a response was received
manifest.json:1 Failed to load resource: the server responded with a status of 404 (Not Found)
Don’t know why I didn’t think of this yesterday, but I connected to my phone’s hotspot and was able to get the audio just fine, so it is definitely being blocked by our school internet for some reason.
WebRTC is considered unsafe in some fields, because it uses p2p for communication which leaks your IP and a few other details.
For low-latency audio in browsers there are not many other choices though…
