How to understand details about my MOD Dwarfs?
Hello. I have two devices with me andI want to have one for home practise and one for performances.
I tried to understand how to do it and found that they are from different series:
  • One is a gift and it is Croudfunded Edition, number is MDW01P01-XXXXX
  • Second hasn’t any special labels and number is MDW02M02-XXXXX
    Questions:
  • Are they identical technically?
  • Which one was produced earlier?
  • Can I use same Pedalboards there?
  • Is it possible to use paid plugins from one on another one?
    I have more questions but they are not related directly to this difference between normal and croudfunded edition.
I think (but am not sure) that those devices are exactly the same specs.
To get the same paid plugins on both devices you should ask @falkTX who can manually send a licence to a device. But it’s clearly not automatic.
For synchronising the pedalboards it may be a ssh copy from one device to another the easiest way !?
I have two units Dwarf, to authorize paid plugins on both unit , I had to contact Gianfranco because it’s done manually on his side.
But there was an issue with third party plugins, here is what said Gianfranco
" The licenses for WOW, TTAP. MEGA Calif. and LP3 Basic are stretch goal licenses and cannot be applied to additional devices. For those plugins you’ll need to purchase if you want them also on the 2nd. unit."
To copy one setup to the other device it’s very easy, just use the backup export/import option via the usb key.
Thank you guys.
Will check the list of plugins that I have on the first one maybe even I do not need them on the second.
