How to switch on discovery mode on Dwarf?
Hey there!
For some reason the Bluetooth discovery mode does not switch on on my Dwarf. At least When I think I turned it on, the Dwarf is not discoverable over the Bluetooth, and the “Status” in the “ENABLE BLUETOOTH” menu says “Unavailable”…
What am I doing wring?
PS Tried searching the forum to no avail.
Take a look here for some hints on how I solved my bluetooth issue.
Hang on, bluetooth dongle? So there’s no bluetooth module inside the Dwarf itself? Now I know why it does not work, huh!
Better bluetooth dongle than no bluetooth at all :grin:
It sure is. I just didn’t realise that there’s no internal Bluetooth in the Dwarf. Thanks!
How do you use BT on your MOD? Can you MIDI-control it over BT?
I use it to navigate to the UI via smartphone or tablet if needed in live stage and rehearsal.
Never tried but I’m confident that it can be done.
Is there an app for this? Basically this (navigating the UI, or, to narrow it down, to switch pedalboards and snapshots) is what I’m after.
No, you have the use your device browser to navigate to UI as you do with desktop PC.
Ah, I see. Thanks! Then I shall explore the path of MIDI over Bluetooth with an android-based control surface.
No, that can’t be done yet (I would personally love it :slight_smile: )
I like the spirit of that “yet” in your response, @jon!
When MOD is back on its feet and you guys indeed focus on the Dwarf as a flagship product, I hope this gets somewhere on top of the feature list for development.
Although personally I would like you guys to fix the ControlChain in the host device first: working with lists = switching of snapshots is still buggy, and I think @falkTX said that the fix was supposed to be implemented in v1.13 that hasn’t seen the light of day yet.
another recommended topic for that: Bluetooth Dongles tested on MOD Devices
