Hi. New Dwarf user here, so forgive what is probably a stupid question. I searched the forum, but found nothing that helped.
I downloaded a few “trial” plugins, loved them, and wanted to buy them. I couldn’t figure out how, so I “removed” the Gaffa trial plugin, expecting it would show up again in the store, so I could select “add to cart”. It didn’t reappear. Nor can I find my cart at all.
What obvious solution am I missing?
Thanks for your help in advance.
Cheers!
Hi @Jon_Grant,
You can add to cart from the information page of the plugin. There are 3 way to access it :
- from the store (be careful about the filters on the left side)
- from the plugin bar at the bottom of the constructor
- from the “i” icon above a plugin present in a pedalboard
You can buy the plugin whether it’s installed as a trial or not. No need to remove it.
Another - maybe stupid - remark: make sure you dont have any filter set on the bar at the left of the screen,
- e.g. “show installed only” or “show not installed only”
- or one of the categories selected
You won’t find a delay in the store if you are only looking at CV Plugins, for example.
I got a bit confused the first time I looked at the store, to be honest…
Thanks for the replies. Whatever the problem was, it fixed itself the next day,vand I was able to successfully buy the plugins. I have no idea why it wasn’t working, but it sorted itself out.
I am enjoying the Dwarf!
