Hi! Received a loog piano recently and am looking for help in understanding what I need to use it as a midi controller with the Dwarf.
The connector on the Loog is USB-C. Any help or recommendations on cables would be greatly appreciated.
If it is this https://loogguitars.com/products/loog-piano, I would think any USB C to USB A cable would be all you’d need.
Indeed; USB A to the usb C on the Loog.
I use a Roland:Go piano as midi controller while I do a bunch of cool stuff on the Dwarf;
Synths but also “sound fonts” for out-of-box grand piano and Fender Rhodes sounds etc.
The flexibility for routing, effects etc on the Dwarf is crazy. Whether you just want to apply some effects to a sound or do your own itty-gritty synth building.
It’s a fun combo and part of why I bought the Roland:GO piano ![]()
Okay. I am feeling really dumb.
So leads me to think maybe the loog just doesn’t work with the dwarf?
It should work
Have you tried adjusing this USB mode setting?
https://wiki.mod.audio/wiki/Dwarf_Device_Settings#USB-B_Mode
Hi! I had not, but that looks to only be for the USB-B. I did try all three settings and changing did not make a difference.
I’m wondering if the MIDI Channel numbering is striking again. MOD MIDI channels start at 0, whereas many other pieces of gear start at 1.
Is there a way to manually set this? I don’t see one, but clearly not a super user.
You should see some midi coming in with the MIDI display - MOD Audio
Which channel your midi keyboard is using ?
Hi Rom. I do not see anything coming in when using that plugin. I am not sure what channel. I did put in a ticket with Loog for help as well.
That means your keyboard isn’t sending any midi
Your mod Dwarf is working properly when you use the audio inputs ?
Did you connect the virtual cable (blue plug on the left) of the USB midi to the plugin?
Hi - I get it, but the keyboard is recognized and works without any effort when using Logic Pro on my mac. So the keyboard is sending midi, but not working with the dwarf atm.
Yes I did. I can get the mod dwarf to work fine with an akai mpkii. Never had an issue. Just the loog doesn’t seem to want to play nice with the dwarf.
Yeah - works fine with another midi keyboard and works fine with guitars/basses.
Can you maybe upload here a little video showing how you are connecting the Loog to the MOD Dwarf and showing also the pedalboard setup that you are running inside the MOD Dwarf?
Another question is: on the MOD WebGUI does the Loog appear listed on the MIDI inputs?
Just confirmed a cable I was using wasn’t working properly. So I am ordering a new USB-A to USB-C. Hopefully have it tomorrow to test with. Re: Mod WebGUI. Unsure where to check the midi input where it would say if it is connected or not.
I think at the bottom rightish of the GUI in the MIDI ports list MOD Web GUI User Guide - MOD Wiki
Hi all - New cable came in. Happy to say that it worked flawlessly. Sorry for not starting there with my troubleshooting and wasting anyones time.
-Randal
