Check it out, an x86 Intel Atom based Pi, for $50:
https://dlidirect.com/products/atomic-pi
Something like this would be a MOD powerhouse.
- Genuine Intel Atom x5-Z8350 quad core with 2M Cache. Runs up to 1.92GHz with a 480MHz GPU. Eats RPi for dessert. Beats some desktops.
 - Loaded with memory: 2GB DDR3L-1600, 16GB eMMC, SD slot for adding more - up to 256GB
 - Full HDMI port with Intel HD Graphics & primary audio out
 - USB 3.0 and USB 2.0 ports
 - Fast dual band WiFI b/g/n/ac 2.4 & 5GHz WiFi RT5572 IPX connectors on board
 - Bluetooth 4.0 CR8510
 - Gigabit hardwired RJ45 Ethernet RTL8111G
 - 9-axis inertial navigation sensor with compass BNO055
 - Secondary XMOS audio output with class-D power amp.
 - TTL serial debug and expansion serial ports up to 3.6Mbps
 - Real time clock & battery
 - JST style connectors on top and a 26-pin header for power & GPIO below.
 - Runs on 5V. Typically 4-15 watts.
 - Legitimate licensed BIOS boots from SD, USB, or Ethernet. Linux comes preloaded… Yes, it’ll run Win10 32 or 64.
 - Large full breakout shield available with screw terminals for easy wiring, or order just the CPU and provide your own wiring.
