right after starting the MOD and loading the first Pedal Board, the headphone output is rather low in volume. I tried two different headphone models, with the same result. After replugging it several times, volume goes back to normal.
Powered up the device with the headphones plugged, Volume seems normal
Unplugged and replugged the headphones, volume is low
Turned Headphone volume all the way down to -33 and back up to 0, volume seems ok
Unplugged and replugged the headphones and volume is much higher, though from what I can tell about my DT-770 Pro, that level is comfortable
@jesse Can you confirm, that the two output plugs are stable in regards of volume? I wouldn’t like any (especially loud) surprises when running the MOD in front of my amp.
yesterday I received my Mod. Really great stuff, I love it…
But this bug seems to still be there (firmware 1.3.2). It almost made me return the Mod on the spot because I then had to turn up the gain a lot to get a suitable volume. Then of course everything started to clip pretty early. So I thought it was unusable for my purpose…
By accident at some point after switching it off and on again it started working. Then I searched and found this old entry. Saved. But I guess this bug should either be fixed or documented somewhere prominently. And of course it is kind of inconvenient…
